AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Pipe, rolling offset
6 REPLIES 6
mario
2531 Views, 6 Replies
Has anyone been successful in creating a rolling offset with the piping tools. using 45 degree elbows, should be fairly simple, but not cooperating. thakns
6 REPLIES 6
Martin__Schmid
in reply to: mario
Is this what you mean:
http://www.screencast.com/users/MartinSchmidADSK/folders/Jing/media/8146aa93-01ef-43f5-812a-0df0ec1c7f18
Your issue may be that the pipe routing preference you are using doesn't have any 45 elbows.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
in reply to: mario
You can change the routing prefrence to use 45 degrees elbows.
OR one way around it is:
As your're drawing the pipe, in the properties box, change your slope to 45, draw a piece of pipe and then change your slope back to 0. You can then go back and adjust your elevation as neccessary.
mario
in reply to: mario
Yes, that helps, I am used to using Bently Plant space products (much more user friendly). Thank you
I am able to use 45 degree elbows now, but is it possible to use 45 degree elbow with a 45 deg lateral in a run? or beter yet a 45 deg elbow with a 45 deg weld-o-let or take off?
Thank you again for the help!
mario
in reply to: mario
Martin__Schmid
in reply to: mario
Something like this?
http://www.screencast.com/users/MartinSchmidADSK/folders/Jing/media/ba5db4a1-6471-4932-aa5c-f58220e8d4ff
Again, it is going to come down to what parts you have defined available in your routing preference.
Martin Schmid
mario
in reply to: mario
Yup, that is what I need, I guess I just need to get used to the process and better aquainted, thanks!
”Boost
