style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"djarvis" <I
href="mailto:djarvis@acdp.co.uk">djarvis@acdp.co.uk> wrote in message
href="news:f1a42aa.-1@WebX.maYIadrTaRb">news:f1a42aa.-1@WebX.maYIadrTaRb...
am attempting to produce a parametric part resembling a circular duct pressed
twin bend as defined in DW144 by the HVCA. However I am having trouble
constraining the arc I am using to define the path of the duct.
I have created a top view plane, then created 2 arc geometries (total of 3
points as the 'start' point for each arc is incidental). Next I created a
circular profile that I have used for the 'modifiers - add path command' to
path the circle along the two arcs, and this works fine at the initial
diameter.
However when I change the duct diameter, which is linked to the diameter of
the curve, the curve paths included angle goes bonkers. Going above 90 degrees
if I increase the diameter and below 90 degrees for a decreased diameter.
How do I set up the part so that the included angle is always 90 degrees? I
have tried placing a point at the middle of the arc and dimensioning this
point to constrain it to set percentages of the diameter but to no avail.
I have uploaded the parametric part to the relevant section of the
newsgroup (consumer files or whatever...) under the same subject title.
Thanks for any help you can give me.
Drew Jarvis,
ACDP, Maidenhead.
