Sorry. In my search for the 'holy grail', I did overlook the title 'Drawing
Units' at the top of the help screen. Thanks for your patience and reply.
"jason martin [Autodesk]" wrote in message
news:2914FF47C20A0A1473A4BB6045A2A2EA@in.WebX.maYIadrTaRb...
> Hi Rick -
> If I'm looking at the right thing, then this is refering to changing the
> drawing UNITS not drawing scale. If you look at the units tab (do this
with
> a copy of a drawing, not a real one until you get a feel for how it works)
> you can change the units from, say english to metric. When you Click OK,
> you'll get another dialog, asking what you want to do with paper and model
> space objects.
> hth
> jason
> "Rick Laur" wrote in message
> news:DF997097FEBDF4E9726E7D41D0F2DED0@in.WebX.maYIadrTaRb...
> > The single drawing multiple scale issue that has been posted several
times
> > is also an issue with our firm. While going through the BS 2004 and
> > reviewing different menu items, I came across the 'Drawing Setup' help
> > screen. at the bottom of the help page (item #12) it mentions 'Specify
> > scaling of existing objects for Model Space and Paper Space" and goes on
> to
> > describe what appears to be a solution for multiple scaled files.
However,
> I
> > cannot find this toggle anywhere in the Drawing Setup menu. Does this
> > actually exist and if so how do I access it? Does it actually allow
> multiple
> > scales inside the same drawing file?
