AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Multi-Circuit Multi-Panel Home Run
0 REPLIES 0
Message 1 of 1
543 Views, 0 Replies
I'm really trying to wrap my head around AMEP to see if it's truely a viable option for my company.  This morning I spent my time working with Home Run Schedules, and for basic schedules, it worked out pretty easy. However, if I found myself with a multi-panel home run, the tag came through in a way that you could assume what it meant, but couldn't tell 100%.
I've attached the file I was working in. Does anyone know how to change the tag (I know how to add (like the Home Run & Home Run Label) and move things around, but format this one I do not know how to do) so the outcome of the clouded Home Run Tag looks something like:
HR-1
LP1(1)
LP2(10)
Thanks very much in advance!
Also, anything else is red is on my to-do list.  If any of you have suggestions or solutions, those would also be very much appreciated.
0 REPLIES 0
”Boost
