AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Modifying duct sizes
4 REPLIES 4
goyete
1244 Views, 4 Replies
Hello, I have duplicate the duct catalog for editing and personalyzing the duct sizes trough the Catalog Editor. I restart AutoCAD and if I go to Style Manager, HVAC Objects, Duct Part Routing PReferences I can select my modified new duct part.
For example, the standar round ducts goes from 63 mm to 1.500 mm. I want for example add a 77 mm duct size.
Then If i draw a duct with a Duct Part Routing PReferences with the new duct part, I don't see the new 77 mm dimension in the list of the diameters of the duct. How can I update this list??
Thanks you.
4 REPLIES 4
VitalyF
in reply to: goyete
You will see new dimensions, if draw a duct in the project file
step by step:
1. Open the catalog, add a new dimension, save catalog
2. Run the project, open the file and draw a duct with new dimensions
Vitaly
VitalyF
in reply to: goyete
Small clip additionally
smbrennan
in reply to: VitalyF
Also, don't forget if you duplicated your catalog - did you double check that your active catalog is the one you changed?  Check your options.
Shawn B.
To help improve Autodesk Products, please Click Here to Vote for ideas and submit your own.
goyete
in reply to: smbrennan
Hello, thanks for your replies.
Vitaly, Is the first time I see the Proyect Browser in your video and I don't use it till now, I'm trying to learning it. Now I'm working in a Project with 3 plants but I usually work in a plane with all the DWG refx for each plant.
Working with the Project browser, I see that AutoCAD makes different DWG with each Construct or View and If I draw a vertical duct in plant 0 and I have a view showing plant 0 and 1, this view doesn't shows the duct drawed in plant 0. Do you understand? Is there any way to see only a plant? If I work in an unique modelo with 3 DWG referedX I don't see anythin becouse the 3 DWG mixes.
Thank you smbrennan85 I don't have duplicated de catalog, only I duplicate the parts. Thank you.
”Boost
