AutoCAD MEP General Discussion
New Member
farfalu
Message 1 of 3 (461 Views)
Accepted Solution
Missing orange triangle alerts
461 Views, 2 Replies
08-22-2012 08:52 AM
The orangle triangle alerts on the end connections of duct and fittings has disappeared and I can't figure out how to get them back. The reason I need them is that it makes it super easy to connect to the duct or fitting if those symbols are there.
I did do an audit of my drawing, would that casue them to disappear?
any help would be great,
*Expert Elite*
Keith.Brown
Message 2 of 3 (460 Views)
Re: Missing orange triangle alerts
08-22-2012 09:16 AM in reply to: farfalu
They more than likely got turned off accidently.  Luckily they are very easy to turn back on.  Switch to the view tab on the ribbon and on the MEP View Panel hit the solution tips button.  Or alternately just use the command SOLUTIONTIPSTOGGLE.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
New Member
farfalu
Message 3 of 3 (454 Views)
08-22-2012 09:22 AM in reply to: Keith.Brown
That worked like a charm......Thanks so much!
You are not logged in.
Announcements
Need installation help?
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
