AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
MEP 2013: Duct, Add Property Sets
1 REPLY 1
saidriad71
609 Views, 1 Reply
Hello all,
When I draw duct work, then select any duct I have drawn, right click and select properties, if I then go to the "Extended Data" tab, I will not see the property set definitions "DuctObject".
The only way I can have it display on the extended data tab, is if I go to the bottom left hand corner of my tool palette, to "Add Property Sets", and then press "ok", I don't have to select "DuctObject" before I press ok because they are already selected.
Is there a setting that will make the "DuctObject" display on the extended data tab of the tool palette automatically?
Please, realy need help!
1 REPLY 1
Keith.Brown
in reply to: saidriad71
Property sets are not added automatically to objects as you draw them.  So when you go to the extended data tab you will not see any property sets until they are added which is the exact process that you described.
”Boost
