VitalyF showed me something new, because that did not use to happen. Well I guess it does now with my version of 2014.
In the past you had to go to the style manager drop down and choose routing preference. choose PVC glued conduit type on the left. on the right you will see that PVC Plastic glued conduit goes to 6" but the fittings only go to 2". so the 6' size was being restricted by the 2' fittings. Change the fitting size to none for "tees" and c's. now when you go to run PVC plastic glued the size will go up to 6".
Yes, I can see conduit go up to 6" but how come when I made conduit biger more than 4",
conduit showing ID not OD. Please advise
You probably need to edit your catalog.
If you are the sole worker for this type of work at your office, you don't necessarily have to do much more. However, if you are one of many, you may want to look into centralizing the Catalog Database on a shared server. Perhaps even lock down permissions.
I would also like to add a word of caution. Be sure to make a copy of the file before editing the catalog.
I am curious as to why the change from ID to OD. When I have time I will take a closer look. Here is one thing I would like to add from a field electrician point of view. 2-1/2" trade sizes and up all share the same O.D. So a one hole strap or unistrut strap or even connectors are all the same size between EMT, Ridged and PVC. I am not sure if autodesk has picked up on that and that is why you are seing the change to the OD measurement. Conduit fill is different above and below 2-1/2" because of the change from using a consitent ID measurement for all conduit types under 2-1/2 and OD over 2-1/2"
I think Autodesk's intent was to make different types (or as they refer to them, a Style) so that users can gain benefits that MEP natively includes, such as tagging and scheduling. So, from our view, yes it looks the same in the end. But, for the companies that use more features than others, it means automated take-offs of conduit lengths, scheduled fittings, etc.
thank you all, I got all conduit sizese I wanted but one more issue is how can I fill out conduit elbow.
I know how to fill out conduit size and radius but I cannot understand and fill out A1 and D1.
Please help.
If you refer to my original post, I tell you what those values are.
LenA1 is in reference to the amount of STRAIGHT conduit beyond the bend. If you know conduit bending methods - this is that extra length that's used to not crimp the the conduit itself during the bend (not so much w/ PVC - but you still need a round end for fittings nontheless.
D1 is your outside diameter.
*Edit: Your Trade Size is the Nominal Size/Inside Diameter. That value is represented by ND1 (Nominal Diameter).
See also >>
