AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Info explaining pitfalls having to do with BACKWARD Compatibility
2 REPLIES 2
mdhutchinson
669 Views, 2 Replies
Could someone point me to a doc that does a good job on explaining backward compatibility in MEP...  2013 saving back to past releases?
2 REPLIES 2
We do not have a document, but have two TS’s.
From 2013 File Format change: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18801721&linkID=9240617  (Applies to Core AutoCAD, but not entirely to AEC verticals.  Ie. Cannot save backwards across file format.)
From 2010 File Format change: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13117479&linkID=9240657
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Mike,
Did the above links help?  That's all the documentation we have other than the myriad forum posts on this topic.
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
”Boost
