Could someone point me to a doc that does a good job on explaining backward compatibility in MEP... 2013 saving back to past releases?
Solved by Joshua.Benoist. Go to Solution.
We do not have a document, but have two TS’s.
From 2013 File Format change: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18801721&linkID=9240617 (Applies to Core AutoCAD, but not entirely to AEC verticals. Ie. Cannot save backwards across file format.)
From 2010 File Format change: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13117479&linkID=9240657
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Mike,
Did the above links help? That's all the documentation we have other than the myriad forum posts on this topic.
Joshua
