AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
How do you find an MvPart in a drawing by "handle"?
3 REPLIES 3
dbillion
493 Views, 3 Replies
Greetings,
I'm working in AutoCAD MEP 2011.
When running a clash detection of a 6-story building in Navisworks (each floor is a separate construct file), I can select an MvPart in the view and get that element's handle (unique identifier).  How can I find that particular part in the construct file, by searching for its handle?
Is there a lsp routine out there that allows the user to enter a MvPart's handle, and have the program zoom to that part?
Many thanks,
Dave
3 REPLIES 3
jcampbell924
in reply to: dbillion
Dave,
Try the below
code:
(defun C:HANDLE ( / handle ent )
(setq handle (getstring "\nEnter handle to search for: "))
(setq ent (handent handle))
(if ent
(progn ;line added
(sssetfirst nil (ssadd ent))
(command "_zoom" "_Object" ent)
;Else
(ALERT "The handle you entered does not exist in this drawing!")
(princ)
(defun OwnerName (handle)
  (cdr (assoc 2 (entget (cdr (assoc 330 (entget (handent handle)))))))
dbillion
in reply to: jcampbell924
Works!  Just what I was looking for.  Thanks.
jcampbell924
Welcome.  You may want to mark my post as the solution.
”Boost
