Hi Andrew:
I finally found the problem after took look at your drawing. The duct and
takeoff have different connection types.
The haloed line gap width will apply to takeoffs after you MOVE or COPY the
duct run if the duct and takeoff have different connection types.
I suggest you to use 'auto-layout' to generate the take off (the takeoff
will automatically match the duct connection type) to avoid this happens.
Also I'll log this as a defect in our bug tacking system.
Thanks.
Qi Liang
"Andrew"
wrote in message
news:B1BE75E69F48D5A8C4A3BF9DEF820B97@in.WebX.maYIadrTaRb...
> I should add, I haven't changed any ABS content. Everything is straight
out
> of the box.
> "Andrew" wrote in message
> news:09B8B0FDB8E213A1D3405CB229B9DAEE@in.WebX.maYIadrTaRb...
> > I placed it in customer-files under the heading "Gap width applies to
> > takeoffs".
> > "Qi Liang" wrote in message
> > news:66B5B33E166491F347781025512D0C2F@in.WebX.maYIadrTaRb...
> > > Hi Andew:
> > > We still cannot reproduce the problem. Would you mind send me a
drawing?
> > > Thanks.
> > > Qi Liang
> > > news:8572AFBD2345B431B71B0B682324DB2A@in.WebX.maYIadrTaRb...
> > > > The main duct is 20" dia. The takeoff is a 10" dia. round beveled
> > > takeoff.
> > > > I used a 3" gap. I've attached an image to illustrate.
> > > > Thanks,
> > > > Andrew
> > > > news:AAA595A5901E05A4C1DA6F7D0FF8B2D4@in.WebX.maYIadrTaRb...
> > > > > Hi Andrew:
> > > > > I did testing. The display is good for the takeoff with haloled
line
> > > come
> > > > > with gap width. Could you please give me more infor? And what's
the
> > > object
> > > > > size you used, what the gap size you set?
> > > > > Thanks.
> > > > > Qi Liang [autodesk].
> > > > > news:7DEF1430557B648A30BE4DB2B7BE016A@in.WebX.maYIadrTaRb...
> > > > > > When I give a gap width under options for Building Systems
Crossed
> > > > > Objects,
> > > > > > it applies this to crossed ducts correctly but why does it apply
> it
> > to
> > > > > > take-offs? It ends up looking like the main duct is broken and
> the
> > > > > take-off
> > > > > > is sitting in mid air. Is there a setting to control this?
> > > > > > Thanks,
> > > > > > Andrew
