From Model I made 3 view ports.
How can I turn layers off in each view port? Please help!
for me, the only way is to do the same but in paperspace, it's easier to manage because in objectspace when you turn a layer off, you do it in all the drawing but not in only one viewport.
Best regards.
A French Autodesk Cad Manager
The old autocad way is to click inside of the viewport and make modelspace active. If you then freeze a layer it will only freeze in that viewport.
If you are using the project navigator then you would basically have a view drawing for each viewport that you would have in your sheet drawing. In your project settings you would have the Match Sheet View Layers to View set to yes. This will sync the layers on your view drawings to the viewports on your sheet drawings.
