I found some posts regarding text stacking in tags, but they were old and with no resolutions.
So, has a way been found to stack fractions in tags? I have duct that I have labeled with size and system abbreviation, TOD, BOD and when necessary insulation and/or liner. BUT, I want the fractions stacked when elevations are such. Non-stacked fractions look like crap and take up way too much space unnecessarily.
Also, is there a way to L, R, MC, justify the tags?
hey Kayrondad,
As far as the justification, when you make the tag, justify the text the way you want it. If you want different justifications for the same tag you are out of luck. You will have to remake the tag for each justification.
For the stacked fractions, I was able to do it once but do not remember how I did it and I am unable to repeat it. I have tried so many times to duplicate the feat but no luck. I am starting to think that I imagined it.
that is what i figured for the justification. It just is not worth the hastle to create all that. As for stacking, I thought I saw it stacked in a tag once, but cannot recall where. I am still not giving up and if I figure it out, I will post for all the rest. If another already knows, PLEASE speak up, I am running out of hair to pull out.
