AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Ductwork Elevation Changes
3 REPLIES 3
Walksy
674 Views, 3 Replies
Hi there, was wondering if you can help me with a simple issue.  I'm a new user to MEP and am just getting into drawing ductwork.
I have ductwork running at a high elevation, dropping down under a beam, running under it and then transitioning up at a high elevation again.  How do I draw the ductwork and 'cycle' through the options of transitions ?? (ie. 15 deg., 30 deg., etc.).
Thanks very much.
Tags (1)
3 REPLIES 3
Joshua.Benoist
in reply to: Walksy
Hi, I made a video that demonstrates how to offset duct under a beam, at a set angle.  The same can be accomplished with the "Offset" fitting in lieu of elbows.  I use elbows in the video, but the same workflow concept applies regardless of the fitting used.  here is a link:
http://screencast.com/t/3SIcjqtgAl2s
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Just following up and wondering if the video helped?
Joshua
Joshua Benoist, PE
Global Services
Autodesk, Inc.
Walksy
in reply to: Joshua.Benoist
Joshua,
Thanks very much for your help, everything worked out great !!
Thanks !!
”Boost
