AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Dissappearing MVParts
5 REPLIES 5
RafaelNova
1112 Views, 5 Replies
I am running into an issue with a 3d file. The file was set up previously using MEP2011. However recently as soon as you move any MVpart it dissappears in plan view but still remains in iso and section views. I followed advice on this forum to use the display manager and the schematic screened to get most of the MV parts to show up again. But things like VD and VAV boxes still do not show up. Also the parts that do show up (mostly registers and diffusers) have had their layers over written so that the do not display/print properly. But again it is only in plan view. Any help on this would be much appreciated!
5 REPLIES 5
Joshua.Benoist
in reply to: RafaelNova
Post the drawing file and make us a video so we know what to look for.  www.jingproject.com is a free video screen capture tool.
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
Just following up to see if you can post us a file and make us a quick video.
Joshua Benoist, PE
Global Services
Autodesk, Inc.
RafaelNova
in reply to: Joshua.Benoist
Sorry about the delay been a little swamped over here. Anyways the file is attached and i have a screen capture of the error happening. Now you cant see it but all of the parts are still there and visible in 3d and section just not in plan.
Thanks in advance for the help
VIDEO:
http://screencast.com/t/l4nEaige1
File:
http://www.mediafire.com/?kgh2bg064stzawa
Joshua.Benoist
Your file was corrupted.  We did a Recover on the file and it found 4 errors.  We then discover5ed that Layer 0 was frozen.  Our MvParts will not display if Layer 0 is frozen.  We then used the command OBJRELUPDATE <select All by tapping the Enter key>, and all MvParts appeared.  We then tested a few by moving them to see if they disappear.  They stayed.  So I think it's fixed.  File is too large to be attached, so I will email direct to you.
Joshua Benoist, PE
Global Services
Autodesk, Inc.
RafaelNova
I did not bother to audit or recover because the file is no longer in use, however unfreezing layer 0 did the trick, didnt even think of that! Thanks so much.
”Boost
