AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Devices with notation; rotation problem
2 REPLIES 2
mciarrocca
220 Views, 2 Replies
We are having problems with devices that include their own notation, such as 3-way switches & GFI receptacles. The device geometry is rotated & appears as we choose. But when checking properties, the rotation is indicated as 119.73 degrees. The notation appears to be rotated by this value. Any suggestions?
2 REPLIES 2
in reply to: mciarrocca
Hi
Could you please provide me with a drawing with a
couple of devices that displays this behaviour?
By the way are you using world ucs or a custom one
(in Current Dwg and any custom Device Content Dwg:s)?
Please e-mail me directly or post it in the
customer files.
/Hakan
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
We
suggestions?
Hi Michel!
Unfortunatly you have discovered a defect that isn't that
easy to get rid of
in ABS 3. The only workaround I could find for now is to
redefine the
annotationblocks themselves to fit your customized UCS..
Unfortunatly you
have to do this for every UCS you work in.
To fix
this I did the following....
1. In the current ucs I inserted the
annotation blocks (for ex:
AECBE_SWITCH_MOTOR_A)in 0,0
2. Then I
switched to World ucs, for reference I also inserted the
Plane
block.
3. Then I moved the Ann blocks (looks like it's rotated)
to a Suitable
Offset (here down right of plan symbol) from the Plane symbol.
Exploded the
block, blocked the annot text with 0,0 as a reference.
4.
Changed back to the custom UCS and inserted the device Unfortunatly the
ones
alredy inserted got screwd a bit so I had to either move their
annotations or
erase the device and reinsert it.
An easier workaround for symbols with
annotations without offsets:
If you dont want the annotations rotated (to
follow WCS) you can redefine
the annotation symbol in the device
style.
In ABS 2004 you do this by selecting one of the devices - right
click and
select symbolstyle - go to the views tab select the annot symbol
under "view
name" (for ex "Text F" in the Fire alarm.... Device Style) and
then uncheck
the keep text horizontal when rotating. OK
IN ABS 2003
you have to: select one of the devices - right click and
selectsymbolstyle -
go to the views tab select the annot symbol under "view
name" and either
remove the view of it or preferrably uncheck all View
directions AND make a
note of which View block its using (in the fire alarm
case:
AECBE_FIRE_LIGHT_A) then you need to add a new view (Add in top right
hand
side) - Enter a view name
- Select Displayrepresentation Plan - Select
viewdirections (Top + Bottom) -
Check Use annotation Scale.
OK
/Hakan
I've logged this as DID 503330
href="mailto:Hakan.Wikemar@Autodesk.com">Hakan.Wikemar@Autodesk.com
Hi
one (in Current Dwg and any custom Device Content Dwg:s)?
customer files.
/Hakan
We
”Boost
