Does anyone know why/how the following happens:
1. My Delete button on my keyboard just stops working. I was working all morning long, then went to erase objects using the delete button on my keyboard and all of a sudden, it was not working. Now in order to erase objects, I have to select them first then type "E" then press enter. It won't even let me type "E" first to start the erase command then select object. I have to do it in a certain order.
2. My right click settings change by themselves.
If anyone has had this happen to them and has a fix, other than uninstalling then reinstalling. Thank you!!!!
As far as the delete button not working it is likely caused by your noun/verb selection setting being unchecked (Option -> Selection Tab -> Selection modes section -> Noun/verb selection - checked) ... the righ-click settings likely changed as the same time - not sure specifically why.
The best solution would be to set you profile how you like it and then export it for future use.
