I recently installed Building Design Suite Premium 2014, with Express Tools. The Express Tools menu appears, but several commands do not work. As an example, If I click the Command Alias Editor icon, I get the response "Unknown Command "Aliasedit. Press F1 for help." At the command line, I manually typed in "Aliasedit", and got the same response. I went to the control panel and brought up the Autocad 2014 program, and clicked on Uninstall/change, then clicked on Add or Remove Features. Even though the Express tool appears in the program, the Express Tools line was unchecked on the Add or Remove Features list. I checked it off, then opened the program again, still doesn't work. I read where others were having the same problem, and it was suggested to remove Express Tools, and then reinstall it. I did that, still doesn't work. Any ideas?
Thanks.
