AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Command Alias Editor Unkown Command
0 REPLIES 0
Message 1 of 1
jgillespie
428 Views, 0 Replies
I recently installed Building Design Suite Premium 2014, with Express Tools.  The Express Tools menu appears, but several commands do not work.   As an example, If I click the Command Alias Editor icon, I get the response "Unknown Command "Aliasedit.  Press F1 for help."  At the command line, I manually typed in "Aliasedit", and got the same response.  I went to the control panel and brought up the Autocad 2014 program, and clicked on Uninstall/change, then clicked on Add or Remove Features.  Even though the Express tool appears in the program, the Express Tools line was unchecked on the Add or Remove Features list.  I checked it off, then opened the program again, still doesn't work.  I read where others were having the same problem, and it was suggested to remove Express Tools, and then reinstall it.  I did that, still doesn't work.  Any ideas?
Thanks.
0 REPLIES 0
”Boost
