AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Can't install from Deployment image
3 REPLIES 3
smathewson
803 Views, 3 Replies
I have created a deployment image for MEP 2013from the Building Design suite 2013. However, when I try to install onto the client machines, it gets so far, then starts to "roll back" everything and then quits. I have tried several variations on the deployment but none seem to have any effect, and the same thing happens. We already have architecture 2013 installed - would this have any effect (have tried deployments both including and excluding architecture)?
Tags (2)
3 REPLIES 3
DarrenP
in reply to: smathewson
what does the install log say?
there should have been one created when you created the deployment
DarrenP
smathewson
in reply to: DarrenP
2013/1/4:14:30:56 Steve.Mathewson WELLWOODPC02 === Setup started on WELLWOODPC02 by Steve.Mathewson === 2013/1/4:14:30:56 Steve.Mathewson WELLWOODPC02 Launch 2013/1/4:14:31:39 Steve.Mathewson WELLWOODPC02 === Setup ended ===
2013/1/4:14:31:07 Steve.Mathewson WELLWOODPC02 === Setup started on WELLWOODPC02 by Steve.Mathewson === 2013/1/4:14:31:07 Steve.Mathewson WELLWOODPC02 Launch 2013/1/4:14:31:40 Steve.Mathewson WELLWOODPC02 Installing DirectX Runtime: \\SBSSERVER\xxxxApplications\MEP2103\AdminImage\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/4:14:34:11 Steve.Mathewson WELLWOODPC02 Install DirectX Runtime Succeeded  2013/1/4:14:34:11 Steve.Mathewson WELLWOODPC02 Installing AutoCAD® MEP:  TRANSFORMS="\\SxxxR\xxxx Applications\MEP2103\AdminImage\x64\en-us\MEP\MEP.mst;\\SxxxR\Terastation\share\0004_Software Applications\MEP2103\AdminImage\x64\MEP\MEP-mep2013.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="\\SBSSERVER\xxxx  Applications\MEP2103\AdminImage\" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/4:14:37:14 Steve.Mathewson WELLWOODPC02 Install AutoCAD® MEP Failed Installation aborted, Result=1603 2013/1/4:14:37:14 Steve.Mathewson WELLWOODPC02 Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/1/4:14:37:16 Steve.Mathewson WELLWOODPC02 === Setup ended ===
(server details altered)
emily.xu
The installation failed at MEP installation with 1603 error. Can you check if this solution works?
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Product Support
”Boost
