AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Block Swapping
5 REPLIES 5
228 Views, 5 Replies
Block Swapping
About half the projects I work on as an electrical designer, we receive
receptacle/data/fixture, etc, layouts from the architect. Typically, we
prefer to utilize our own symbols for these devices/fixtures, etc.
Is there a simple way to essentially replace the architect's blocks with
ours? I.e., this could be done by using refedit to make their block look
like ours, but then there is the liklihood that their blocks are not on our
standard device layer. Also likely, their blocks may be inserted at a
different scale than ours, so if you rename their block to match our name,
there is the liklihood that our menu inserted blocks will be inserted and
appear to be the worng size.
I'm working on a simple ARX utility to do what I need... but was wondering
if this is functionalityh is built into ABS or ADT - I'm currently only
using Acad2000.
Martin Schmid, EIT, CCSA, MCDBA, MCSE
5 REPLIES 5
I found 'blockreplace' in the Acad2000 express tools after posting this,
however, that utility doesn't address the scaling issue, the layer issue, or
another issue--- that the architect's block definition orientation may be
different (i.e. rotated 90, 180, 270, etc) degrees from our definition...
leaving the replaced blocks in the wrong orientation, layer, and scale.
The function I created addresses these issues.. however... is this
functionality already in ADT or BS somewhere else?
"Martin Schmid" wrote in message
news:7F82E90DAA7555C7B596FC03B117775B@in.WebX.maYIadrTaRb...
our
> using Acad2000.
> Thanks,
I've got ABS4 with the Express Tools loaded and it
works for me.
Try using the Express Tools that come with
ABS4.
Matt W
There are 3 kinds of people:
  Those
who can count, and those who can't.
I
this,
issue, or
orientation may be
our definition...
layer, and scale.
however... is this
else?
MCSE
"Martin Schmid" <
href="mailto:martinschmid@sbcglobal.net.nospam">martinschmid@sbcglobal.net.nospam
wrote in message
href="news:7F82E90DAA7555C7B596FC03B117775B@in.WebX.maYIadrTaRb">news:7F82E90DAA7555C7B596FC03B11...
receive
> ours?  I.e., this
> like ours, but
our
a
name,
inserted and
> I'm working
> if this
> using
Acad2000.
> Thanks,
> Martin Schmid, EIT,
CCSA, MCDBA, MCSE
How does it work?  I don't have ABS.
it works for me.
ABS4.
Matt W
Those who can count, and those who can't.
I
this,
issue, or
orientation may be
else?
MCSE
"Martin Schmid" <
wrote in message
href="news:7F82E90DAA7555C7B596FC03B117775B@in.WebX.maYIadrTaRb">news:7F82E90DAA7555C7B596FC03B...
receive
> ours?  I.e.,
> like
on
our
be inserted at a
size.
> using Acad2000.
> Thanks,
MCSE
You don't have ABS?? I think you're in the wrong group
then.  Anywho... it allows you to select the block to be replaced, then the
block to replace it with.
It's pretty sweet!
Matt
W
those who can't.
and it works for me.
ABS4.
Matt W
I
this,
layer issue, or
orientation may be
somewhere else?
MCDBA, MCSE
"Martin Schmid" <
wrote in message
href="news:7F82E90DAA7555C7B596FC03B117775B@in.WebX.maYIadrTaRb">news:7F82E90DAA7555C7B596FC0...
receive
> ours?  I.e.,
> like
on
our
size.
> using Acad2000.
> Thanks,
MCSE
>>You don't have ABS?? I think you're in the wrong group then.
Didn't you read the whole post? I'm trying to find out info about ABS
2004 - is believe this is the correct forum for that! Please re-visit my
question.
I am in the process of developing this capability to suit my needs - I am
currently using Acad2000 but will be going to ABS soon - didn't want to
reinvent the wheel. Here is a rehash of my question - does ABS or ADT
address these issues?
Anyway - the block replace I found described (and is in the express tools)
only replaces the block - it doesn't take into consideration some key
problems - i.e., given a simple receptacle:
1. Architect's block may be oriented up-down, whereas the MEP block used
may be oriented left-right.
2. Architect's block may need to be scaled to 8.0 for a 1/8" drawings,
whereas MEP block may need 96.0 scaling
3. Architect's block(s) may be on - layer ELEC, our block may need to be on
E-POWR-WALL
4. Architect's block may have a different relative insertion point.
The block replace express tool only replaces the block, these items are not
addressed; therefore replacing the block has a tendency to leave the block
rotated incorrectly, scaled inappropriately, on the wrong layer, and not
quite in the correct position. Does ABS (or ADT --- WHICH ONE?!) address
these issues?
"Matt W" wrote in message
news:F725EF1B278D9367789FB324288CCF88@in.WebX.maYIadrTaRb...
You don't have ABS?? I think you're in the wrong group then. Anywho... it
allows you to select the block to be replaced, then the block to replace it
with.
It's pretty sweet!
Matt W
news:A613C64A6D5BB163702E5A7574A7EFDD@in.WebX.maYIadrTaRb...
news:0F6380D96AE5D6C550F255E9CA96245C@in.WebX.maYIadrTaRb...
I've got ABS4 with the Express Tools loaded and it works for me.
Try using the Express Tools that come with ABS4.
Matt W
news:684FF925775176868077F7A7893005CF@in.WebX.maYIadrTaRb...
our
> using Acad2000.
> Thanks,
”Boost
