AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Bevelled duct
2 REPLIES 2
jcharles2417
699 Views, 2 Replies
Bevelled duct
Is there a way to terminate an open-ended MEP duct with a bevel cut? i.e., for a section of duct connected to an exhaust fan discharge? Smiley Sad
2 REPLIES 2
pothied
in reply to: jcharles2417
There is no way to bevel cut a duct. Your only option would be to create an end cap fitting with the desired geometry and place that at the end of the duct.
David Pothier
Keith.Brown
Hi JCharles2417,
You might look into creating a custom fitting.  You supply a path and need just start the DUCTCUSTOMFITTING command.  I am not sure if you will be able to get the exact look that you are looking for however.
”Boost
