I was wondering what the easiest way to make duct components (MVPatrs) the protrude from the duct, such as damper handles/actuators, sample ports, etc... show beyond the insulation. I'm pretty good with MEP, but have just started using it again, after about 2yrs away. Our client wants the model & plans to show with insulation (sometimes as much a 6" for the heat exhaust), but it obviously covers up the damper handles, for example, and you are unable to even tell it's there, & turning off the insulation so they show is cheesy & makes it look like something is wrong.
Should I modify the existing mvparts (& any good tutorial on that, out there btw...) or would I be better off creating an MVPart that I can anchor to the damper and/or duct that essentially makes it look like the part is extended beyond the insulation?
I can't imagine I'm the first person to run across this, how is this problem solved by others?
Solved by Keith.Brown. Go to Solution.
You should modify your existing mvparts in my opinion. You dampers should have a parametric handle length so that they can be adjusted for any size of insulation.
Joshua Benoist has a nice tutorial at Autodesk University on how to create/modify mvparts.
The thank you VERY much - I should have thought about AU in the first place! That is exactly what I was lookng for!!!
