style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Mike" <
href="mailto:hisalone@intercom.net">hisalone@intercom.net> wrote in
message
href="news:358FB8A88408DC49EC5D22777E689070@in.WebX.maYIadrTaRb">news:358FB8A88408DC49EC5D22777E6......
I was hoping to use my old catalogs from BS3 in
BS4 until a new catalog can be prepared using the BS4 generic catalog.
The problem I'm having is that BS4 will not recognize the Grooved connector
when I try to use grooved pipe. Is the Grooved connector name changed
somehow that BS4 doesn't recognize it? Is there something I can
change in the catalog to make it work?
size=2>Thanks,
Mike
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Hi Mike!
lang=EN-GB>
size=3>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Just to be clear: The grooved pipe
still exist in ABS4 but in the original Pipe catalog.
lang=EN-GB>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">If you want the grooved pipe to
exist in the Plumbing 3D catalog as well its as you say a more hidden
process, but easier 🙂
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">The easiest way of accomplishing
this would be just to copy the content from the original place into
the catalog structure of 3D plumbing and do a catalogregen on the pipe
catalog.
size=3>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">That is if you would like to copy
the grooved Connection type for Schedule 40 from ABS3 (or ABS 4) into your
plumbing 3d pipe catalog you would have to copy the:
lang=EN-GB>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><C:\Program Files\Autodesk
Building Systems 3\Aecb Catalogs 3\Pipe
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">US
lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> Imperial\Schedule
40\Grooved>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Catalog and paste it into
the:
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><C:\Documents and Settings\All
Users\Application Data\Autodesk\Autodesk Building Systems 2004\R16.0\enu\Aecb
Catalogs 4\Pipe
40>
lang=EN-GB>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">(This is if you have
installed your content in the default location,
lang=EN-US
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-ansi-language: EN-US">otherwise
lang=EN-GB style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> use your custom
paths)
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">Then you will have to do a
CatalogRegen on the pipe catalog, and then your parts should be
available.
size=3>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">You can also use the Catalog editor
if you want to and drag and drop/copy paste things between different
catalogs.
size=3>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">hth
lang=EN-GB>
style="FONT-SIZE: 10pt; FONT-FAMILY: Arial">/Hakan
lang=EN-GB>
"Mike" <
message
href="news:CF02BCC301B6BFC178F5270A09A0D574@in.WebX.maYIadrTaRb">news:CF02BCC301B6BFC178F5270A09A......
Can anyone from Autodesk help out about this
problem? It should be an easy enough fix, how can I get my grooved
connection from ABS3 piping to work in Plumbing 3D? Is there a way to
add this connection type to the plumbing catalog? Is it just an
XML edit or some other more hidden process?
Mike
"Mike" <
message
href="news:358FB8A88408DC49EC5D22777E689070@in.WebX.maYIadrTaRb">news:358FB8A88408DC49EC5D22777......
size=2>Thanks,
Mike
"Mike" <
message
size=2>Thanks,
Mike
"Mike" <
message
href="news:17758ADD10756712D2F604E088E7D1AA@in.WebX.maYIadrTaRb">news:17758ADD10756712D2F604E088E......
Hakan,
I posted a picture of the error message and
a small file of Acid fittings in the Autocad.customer-files area with the same
subject. If you put the Items in your piping folder then try to use
them, you will most likely get the same error I get.
Mike
"Lars-Ake Johansson [Autodesk]" <
href="mailto:lars-ake.johansson@autodesk.com">lars-ake.johansson@autodesk.com>
wrote in message
href="news:BBD308F8A978F613D490FA881A1A8879@in.WebX.maYIadrTaRb">news:BBD308F8A978F613D490FA881A1......
Hi Mike,
I tested the parts that you posted under customer
files...
There is one vital part missing - the connector.
Don't know if you have it on your computer and just missed to attached it to
the file, but if I defined the connector, your parts worked on my
computer.
Attaching a zip file to the posting in customer
files.
Regards
Lars-Ake Johansson
Autodesk QA
"Mike" <
message
href="news:17758ADD10756712D2F604E088E7D1AA@in.WebX.maYIadrTaRb">news:17758ADD10756712D2F604E08......
Hakan,
message and a small file of Acid fittings in the Autocad.customer-files
area with the same subject. If you put the Items in your piping folder
then try to use them, you will most likely get the same error I
get.
Mike
size=2>
