AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
AutoCAD MEP 2012 panel schedule merging cells, multi-pole settings
1 REPLY 1
643 Views, 1 Reply
PLEASE HELP!
I am a newbie at MEP 2012 (non-Revit) and I am progressing well. Unfortunately, I have come across what should be an easy fix but I can't figure this one out. That being said...
Using basic OOTB electrical panel schedules, I need the nulti-pole circuits to display as a single row of text, NOT as three rows of duplicate information for each panel slot used. I know the  panel adding dialogue has a option for multi-pole circuits to be shown as a single row (merged), but mine is grayed-out.  Is this part of the table style properties?
At any rate, I need this option to be changed/made available for change. Any thoughts, advice, etc.? Again...
PLEASE HELP!!
THANKS IN ADVANCE!
1 REPLY 1
balddude
I was able to do this by changing a multi-pole breaker from 1,3,5 to just 1, 2,4,5 to 2, etc.  It won't save you any time, but it works.
I didn't mix doing this with standard single-pole breakers, so I don't know how it will work.
”Boost
