I am trying to draw up a circuit in a drawing by using the defined duplex given in AutoCAD MEP. When I insert a duplex, the size is a tiny spec. How do I annotate the block that is already pre-defined in MEP? Below is a picture of how it looks once I insert the duplex. The drawing is scaled to 1/8" = 1'-0"
The duplex is in the number 6
Thanks!!
Solved by Joshua.Benoist. Go to Solution.
Your display is set to "Standard" in the bottom right corner. That is often an indicator that you are using a drawing started from a Core AutoCAD template. The MEP default template is: "Aecb Model (US Imperial CTB).dwt" and has a default display called "MEP Design." We should see MEP Design or other MEP display in bottom right corner. With a drawing started from an MEP template, and an MEP display, the device annotative block should be about the same size as the text.
You could switch to model space. Ctrl +A to select All. Ctrl +C to copy all to clipboard. Start a new drawing from the MEP template. Ctrl +V to paste all to the new drawing. Use 0,0 when asked for the insertion point. The device may start behaving annotatively and scale properly.
Hope this helps,
Joshua
Wanted to follow up and see if the above helped.
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
