How do I get my properties box back up on my screen, I was setting up my drwg and I hit autohide on the properties box, I was trying to put it on the side, now I can't get it back.
thanks
You can right click anywhere in your drawing area and select properties way down at the bottom or you can just type PROPERTIES at the command line. If it is still not showing then it is probably on a second monitor or off of the viewable screen area. If this is the case, I have had success bringing it back into the viewable area by changing workspace or my profile. Both of those options store the locations of the palette and by changing to another one you are effective resetting your palette.
