Using MEP 2013, objects that I belive were created using Autodesk Fabrication CADmep come in with their properties. Using 2014 MEP, objects are coing in as proxy objects. I tried installing the object enabler and it came up as already being installed, which I believe came with the 2013 install package.
Any ideas?
I'm pretty sure you need to uninstall the 2013 object enabler in order to load the 2014 object enabler. The program does not overwrite the old program. You can do that in control panel.
