Sorry Doug, thought I saw the old wfb.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"John Mayo" wrote in message
news:6022062@discussion.autodesk.com...
Use them both as Bill said. They are both very useful and powerful tools.
My take on the UCS "problems"
The worst thing that ever happened here was someone imported points with a
UCS set. He set the dwg to World coords, removed the points & reimported in
less than 3 min. Another common "problem" is someone may draw a 3d pline &
they won't see it. They either move & rotate it to the proper location or
redraw it. We have never lost data or a great deal of time from these minor
UCS blunders.
If you like to use UCS's there is nothing wrong with it just keep the
Ucsicon visible at all times so the confusion is avoidable and keep the
staff up to speed.
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
wrote in message news:6018336@discussion.autodesk.com...
Do you have people who will try to use ldd commands when the drawing has a
ucs other than world? Then come bug you about why things dont work? Do you
have to fix the problems people create when they change the ucs then do a
profile?
After you start spending most of your time on trouble shooting other peoples
(self created) problems you will probably try to get people to stick with
dview.
