AutoCAD Land Desktop
Active Contributor
tailleur
Message 1 of 4 (94 Views)
survey 2005
94 Views, 3 Replies
10-13-2004 02:03 PM
Has anyone ever figured out a way to rotate a symbol when importing a field book by means of a secondary survey shot? IE first shot on a traffic signal mast arm post, second shot in the direction the mast arm is hanging. And if so could you enlighten me?
thanks
*Bud
Message 2 of 4 (94 Views)
Re: survey 2005
10-13-2004 07:20 PM in reply to: tailleur
You can use a parameter for rotation via description keys. Bud Miller www.BudCAD.com Legal descriptions and more in LDT "tailleur" wrote in message news:10116122.1097701421779.JavaMail.jive@jiveforum1.autodesk.com... > Has anyone ever figured out a way to rotate a symbol when importing a > field book by means of a secondary survey shot? IE first shot on a traffic > signal mast arm post, second shot in the direction the mast arm is > hanging. And if so could you enlighten me? > > thanks
*Robert Martin
Message 3 of 4 (94 Views)
Re: survey 2005
10-14-2004 02:04 PM in reply to: tailleur
Survey Tools by http://www.rsteltman.com will do it. Robert "tailleur" wrote in message news:10116122.1097701421779.JavaMail.jive@jiveforum1.autodesk.com... > Has anyone ever figured out a way to rotate a symbol when importing a > field book by means of a secondary survey shot? IE first shot on a traffic > signal mast arm post, second shot in the direction the mast arm is > hanging. And if so could you enlighten me? > > thanks
*cadguy
Message 4 of 4 (94 Views)
Re: survey 2005
10-22-2004 06:08 AM in reply to: tailleur
I usually use a compass and enter the bearing of the arm (or sign) and use the description key parameters to define the rotation with the bearing i.e. "SignalMast 032 Single signal" "tailleur" wrote in message news:10116122.1097701421779.JavaMail.jive@jiveforum1.autodesk.com... > Has anyone ever figured out a way to rotate a symbol when importing a > field book by means of a secondary survey shot? IE first shot on a traffic > signal mast arm post, second shot in the direction the mast arm is > hanging. And if so could you enlighten me? > > thanks
You are not logged in.
Ask the Community
