for every 2.5 units H 1 unit V
it is the inverse of 4/10 or 40%>>>>1/.4= 2.5
Joe
Joseph D. Bouza, P.E.
Civil 3D 2006
LDT 2006
Win XP pro
v 2002, sp 2
hp workstation xw4100
In memory of the King of Work-arounds
"The only Constant is Change".
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay."
A reminder taken from Graphics Solution Providers' Calendar page
wrote in message news:5785209@discussion.autodesk.com...
I draw two rectangles with polyline. By using Contour Utility of Terrain
menu, I convert the rectangles to be contours and using Edit Elevation to +8
for outer contour and +12 for other contour.
Here are the descriptions:
1. Contour with elevation +8 has area 120 m x 120 m
2. Contour with elevation +12 has area 100 m x 100 m
3. Contour with elevation +8 is at the outer, or let's make it as boundary
line. But do not define it as boundary. Only a presumption or an
illustration.
4. Contour with elevation +12 is inside contour +8. Precisely, their center
of rectangle is at a same point.
5. Horizontal distance of two contours = 10 m
Then, by using List Slope of Inquiry menu I click at two points of both
contour line (precisely, at the Midpoint of the left vertical contour) from
contour +12 to contour +8.
AutoCAD give results as follows:
First elev: 12.00, Second elev: 8.00, Elev diff: -4.00
Slope: -2.50:1, Grade: -40.00, Horiz dist: 10.00
My questions:
1. What the meaning of Slope: -2.50:1, Grade: -40.00?
2. How to calculate them?
Thank you very much...
Anggidesk
