And one more thing to prevent this instance reappearing in the future...
Export the "new" Profile someplace out of the "reach" of LDT (My Documents
comes to mind), so you don't need to spend those 10-15 minutes in the
future.
HTH
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
"Don Reichle" wrote in message
news:5567845@discussion.autodesk.com...
I'm wondering if this instance you've brought to our attention might be
similar to what Dennis Hyman found himself with regarding the ARG file?
It will only take 10-15 minutes for you to "restore" LDT's Options the way
you need them:
So you could Exit/Save from all but one LDT application;
Then in the one still open, right-click in the Command display on-screen,
and select Options at the bottom;
Then select the Profile tab;
Set the <> Current;
Then Delete the LandDesktop Profile;
Click OK;
Close the LDT app you had open;
Open another LDT application, and it will tell you there's no Profile, and
ask if it should create a new "default" Profile - obviously the answer would
be Yes. ;0)
Then reset all of the items the way you want them mijensen, and get on with
that Project.
HTH
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5567434@discussion.autodesk.com...
Hi
i must have inadvertently screwed up my menus. I cannot right click for
shortcut menus. I've checked tools>options>rightclick customization.
Everything is the way it should be for shortcuts. Is there a way to restore
default menus? If i just fire up acad map, everything works okay, it's just
in ldd that it doesn't function. Any help is greatly appreciated.
thanks
