• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    Valued Contributor
    points in file but not in database
    77 Views, 3 Replies
    01-21-2008 08:39 AM
    I've added points to a drawing through LDD but now the database is not recognizing them. I select the points and there are 835 Civil Point Objects but when I try to add them to a point group LDD won't recognize them at all. I need to get these points in a point group to make a surface and I don't want to go back and re-insert them all again manually!!!! Please help!
    Please use plain text.
    Distinguished Contributor
    Re: points in file but not in database
    01-21-2008 08:50 AM in reply to: three_dogs
    under points --->check points----->modify project---> check the add unregistered points to database. and you should be good to go
    Valued Contributor
    01-21-2008 08:54 AM in reply to: three_dogs
    AWESOME!!! After a couple tries I finally got it using this! Thanks so much! You saved me a few hours of work!
    01-21-2008 09:40 AM in reply to: three_dogs
    no worries mate
