AutoCAD Land Desktop (Read Only)
185 Views, 3 Replies
not reporting
We are running LDDT3 on Widows 2000 machines. when trying to report an alignment on screen or in a file, it is not reporting. The same file with the same project runs perfectly on another machine.
3 REPLIES 3
I've had that problem periodically too. So far the best work around
I've come up with is to turn off the computer and go home. Tomorrow
when you come back it just might work. It worked for me anyway once.
Sorry I don't really know the answer, I'm anxiously awaiting one though.
If you've really got to get it out in a hurry though and don't have time
to try my suggestion above then you could use XML to get your report.
Of course you'll have to spend some time boning up on XML. You can
export your alignment to XML, and then using the alignment style sheet
you get a really nice web report.
j_elliott
Sometimes this work... but sometimes it doesn't... Cross Section pulldown/Ditch Transition/Edit Profile Alignment... select the profile (ie, center, left, right) The report appears, but in a different format then you are used to... select print to file... find the .txt file where ever you saved it to.. and print via wordpad... That's the only thing I have come up with to by pass this wonderful program not giving my the www version of the report... Hope that helps
j_elliott
...correction.. after selecting which alignment you want to view, print.. select STA AND CURVE box at the bottom of the window.. then the report appears.. Sorry, i forgot that step...
