• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Land Desktop
    New Member
    mapbulkfeature
    1541 Views, 2 Replies
    03-18-2010 03:06 PM
    I bring shape files into Autocad 2010. I want to explode the line so that I could change color & line weight. Is there any way for me to handle this mapbulkfeature line.
    Thanks for the help in advance.
    Please use plain text.
    *R.K. McSwain
    Re: mapbulkfeature
    03-18-2010 05:39 PM in reply to: illcad
    In the absence of another suggestion, you could use the ._MAPIMPORT
    command to import the geometry, which becomes polylines. I think you
    are currently using Data Connect, right?
    R.K. McSwain
    http://cadpanacea.com
    Active Member
    Re: mapbulkfeature
    08-30-2012 10:06 AM in reply to: *R.K. McSwain
    I am also having the same problem.  I have imported the shp files using Map Connect, I am able select very few objects and explode them, wanting to explode multiple objects I get an error message about unable to explode mapbulkfeature.
    I have imported the shp files this way because if I use Map>Import>"abc.shp" Cad will crash and not load the entire file.  The files I am working with cover Western Canada and Provincial data, They are enormous files. Not exactly sure what mapbulkfeature is, I am also very new to using shp files. Frustration and anger has set in!
