AutoCAD Land Desktop
New Member
rbtodd
Message 1 of 4 (1,791 Views)
gravel and concrete hatches not correct
1791 Views, 3 Replies
09-05-2008 08:59 AM
when i use the gravel or hatch pattern it doesn't show up correctly. I saw where autodesk said to move to a lower coordinate and then hatch, or to set the drawing limits to include all geometry in drawing. I have no clue how to do this. Any suggestions?
Valued Contributor
dness
Message 2 of 4 (1,791 Views)
Re: gravel and concrete hatches not correct
09-05-2008 10:35 AM in reply to: rbtodd
The problem is distance from drawing base point (default is 0,0,0). In 2007-2008 you can change the hatch origin this will correct the problem. Open the hatch dialog and show more options arrow bottom right. On older versions you can change the base point to a location nearer the hatck.
*jd-drafter
Message 3 of 4 (1,791 Views)
09-07-2008 01:11 PM in reply to: rbtodd
SNAPBASE
select a point near the area to hatch...
then i normally reset it back to 0,0 (only 2d.. not 3d)
that's on ldd 04
wrote in message news:6024409@discussion.autodesk.com...
Active Contributor
nodink
Message 4 of 4 (719 Views)
01-14-2014 02:19 PM in reply to: rbtodd
in paperspace, move all entities closer to 0,0 & re-hatch. That should do it.
You are not logged in.
Announcements
Need installation help?
Ask the Community
