And Land Lizard, an easy method of adding them to the Pipe Run is to 1st
draw the CL along the radius you need. Then use the Multiple command to
place Nodes along the arc at the interval you wish. Connect the Nodes with a
polyline, and you're most of the way to getting what you need. You can then
take advantage of Define Pipe Run>Define By Polyline.
I would look that dimension up in the Pipe Mfg. catalog - you can find quite
a few of them on-line to help with this.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
Intel Celeron 2.5GHz
XPPro 32bit SP2
1GB RAM
Intel 82865G 64MB
"Conan Witzel" wrote in message
news:5155723@discussion.autodesk.com...
Only solution I know is a bunch of PIs with structure set to null. Won't be
perfect.
I hate curved pipes, but they are better in Civil 3d.
Sorry,
Conan Witzel
LDD 2006
