AutoCAD Land Desktop (Read Only)
Message 1 of 11
damian
1540 Views, 10 Replies
base.dcl
I am getting the following errors when launching LDC 2008:
Base.dcl - can't find file
error loading dialog control file
semantic errors in DCL file acad map.dcl
see file acad.dce for details
acfields.fdc is not found
semantic errors in DCL file ade.dcl.
I have found threads to fix for older versions but not for 2008. The program loaded OK the first time but not since. Is there documentation on this?
Thank you for your time.
10 REPLIES 10
Message 2 of 11
in reply to: damian
Can I ask what type of "User" your account is setup as on this PC dfgega?
Control Panel>User Accounts will be useful for performing the
investigation/revision as needed. I've found that being a "Power User" as a
minimum most often prevents the issues you've mentioned.
And since I'm on this subject...
When LDT 2K8 was installed, was it done by someone with an "Administrator"
User account?
And now to cover a few more of these bases, was the PC's virus-scanner
disabled during the install?
And are/were there any other Land Desktop releases installed on the PC,
prior to LDT 2K8's installation?
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5570517@discussion.autodesk.com...
this?
Message 3 of 11
damian
in reply to: damian
Don,
Thank you for responding. Here is more info.
The "user" on this workstation is administrator.
The PC's virus scanner was not disabled during the install.
This PC has LDT 2006 and LDT 2007 installed.
Message 4 of 11
in reply to: damian
See my further comments interspersed with a > preceding them into your
replies below.
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5570567@discussion.autodesk.com...
Don,
>Thankfully we no longer need be concerned over this. ;0)
>So a Repair of the LDT 2K8 through Control Panel with the virus-scanner
>disabled (please also disconnect from the Internet during this Repair -
>just so you're "safe" from virus's making an intrusion.
>Were these two Repaired after 2K8 was initially installed? It is part of
>the ReadMe on each of the release's DVD/CD since the "turn of the century"
>;0)
>HTH
Message 5 of 11
damian
in reply to: damian
Virus scanner was turned off and 08 was repaired. started up just fine. Restarted PC and the same problem came back with 08. Excuse my ignorance but do I have to repair 06 and 07 in the same manner prior to repairing 08?
Thank you
Message 6 of 11
in reply to: damian
Both of them should have been Repaired right after 2K8 was installed dfgega.
Repair both of them prior to your next Repair of 2K8, and I would suggest
that instead of a Restart that you go through the Shutdown instead.. Again
disable the VS for both of those Repairs - just for "safeties sake".
I know I'll likely see someone mentioning that Terminate Stay Resident apps
are no longer an issue these days, but since you mentioned that the issues
came back after your Restart, I'll need further "proof" - before I change my
ways. ;0)
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5571062@discussion.autodesk.com...
Thank you
Message 7 of 11
damian
in reply to: damian
Don,
What I did was:
1. Turned off VS
2. Repaired LDT 2006
3. Repaired LDT 2007
4. Repaired LDT 2008
5. Opened LDT 2008 everything seemed fine
6. Turned off computer
7. Turned on computer, had to unplug and replug mouse
8. Opened LDT 2008 and back to square one with base.dcl errors.
I really do appreciate your time on this matter.
Thank you
Message 8 of 11
in reply to: damian
As from your troubles with LDT 2K8, together with a few of the others I've
seen so far - John Schmidt's Deployment Problem being another recent issue -
I'm beginning to get the idea that some of the troubles that LDT 2K7
experienced last year about this time, have migrated over to LDT 2K8.
Report this problem to your reseller, since there's nothing in the Knowledge
Base (yet) to cover your issue dfgega:
http://tinyurl.com/2xswxu
Which is what that tinyurl will show you - unfortunately.
I'm hopeful that the "fix" will only require one Service Pack, this time
around.
But you never know, I'm thinking.
:-o
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5571915@discussion.autodesk.com...
Don,
What I did was:
1. Turned off VS
Thank you
Message 9 of 11
damian
in reply to: damian
Don,
I contacted Autodesk and they had me delete a file from my registry and start LDT again. It has worked so far.
Thank you very much for your time on this.
Message 10 of 11
in reply to: damian
So with a new release such as this that may be the place to start - rather
than the DG?
At least for the 1st couple weeks, I'm thinking.
Just so we get something to follow here, which item from the registry did
they mention to delete?
Don Reichle
LDT-2K4
XPPro 32bit SP2
wrote in message news:5573684@discussion.autodesk.com...
Don,
Message 11 of 11
damian
in reply to: damian
Don,
FYI this is the file.
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.1\ACAD-6018:409.
Thanks again.
PS new problem with C3D 08 & MS Office 2007 please see comments by KW-EGA
