If you are looking for the acad x,y bounding box, then you will first need
to convert from northing/easting to x,y with the utility function (I forget
it's name) to account for the dwg Land Desktop north rotation.
The other issue to consider is that a min/max coordinate may be a point
along a curve. To deal with this you would check the start and end
directions to see if they are in two different quadrants. If so, you would
calculate the min or max value depending on which two quadrants the
start/end directions are in. For example, if the start direction is SE and
the end direction is SW then you would want to determine the maximum easting
value for this curve. This could be done a number of ways. One approach
would be to get the radius point, then add the radius value to the easting
to determine the max easting on the curve.
Spirals are more difficult. If you are just looking to create a zoom to
function, then I would include the SPI coordinate (along with the start/end)
in my min/max comparison and call it close enough. If you need to be more
exact, you may need to go the route of creating the spirals in the drawing
and using acad to determine the bounding box.
Glen
"Drew Burgasser" wrote in message
news:41E38059244E7A66D90AEFE76460CB18@in.WebX.maYIadrTaRb...
> Coen:
> I don't think you need to draw the entities.
> You can access the alignment entities within VBA. Each entity has a start
> and end northing and easting property.
> You would have to loop through each entity and search for the max and min
> northings and eastings, but I don't think this would be very difficult:
> Dim i as Integer
> Dim nmin as double, nmax as double, emin as double, emax as double
> Dim als As AeccAlignments, al As AeccAlignment, ae As AeccAlignEntities
> Set als = AeccApplication.ActiveProject.Alignments
> Set al = als.Item(als.CurrentAlignment)
> Set ae = al.AlignEntities
> nmin=0 : nmax=0 : emin=0 : emax=0
> For i = 0 To ae.Count - 1
> If ae.Item(i).StartEasting < emin Then
> emin = ae.Item(i).StartEasting
> end if
> If ae.Item(i).EndEasting < emin Then
> emin = ae.Item(i).EndEasting
> end if
> If ae.Item(i).StartEasting > emax Then
> emax = ae.Item(i).StartEasting
> end if
> If ae.Item(i).EndEasting > emax Then
> end if
> etc
> etc
> etc
> etc
> Next
> I wrote this real quick. Obviously, test it extensively before using.
> Good luck,
> Drew Burgasser
> CAD Masters, Inc.
> www.cadmasters.com
> "Coen van Dongen" wrote in message
> news:790AC8AD344992002E37A796B93AD67D@in.WebX.maYIadrTaRb...
> > Hi,
> > does anyone have an easy way of getting an alignments boundingbox? From
> what
> > I've seen so far I will need to loop through all the alignment entities
> and
> > draw them, get the drawing entities bounding boxes and compare those to
> get
> > the max min values.
> > Is there a less time consuming way to do this?
> > thanks,
> > Coen
