AutoCAD Land Desktop (Read Only)
Btimmerman
307 Views, 3 Replies
aeccapp.arx
Autodesk - Why won't you post any replies to this issue?
There are numerous postings about this error with the aeccapp.arx, but yet there are NO replies from Autodesk.
Has anyone found a known solution to this issue.
Again; starting a Civil Series 2004 with current service packs on both app and O/S. The app worked fine yesterday - now the program runs into an exception with aeccapp.arx and shuts down.
System is a PIV with 1Gb Ram on Win X/P Pro.
Can someone from Autodesk reply to this and other items that are floating in the breeze. I've "tried" to contact my reseller and they are non-repsonsive. Is there some known issue with this arx and the solution is a mystery to all?
This isn't my first experience with the software - used to work for said reseller and am no in the business of using the software.
B Timmerman
HHE
Hiawatha, IA
Any help would be greatly appreciated.
FYI - I've tried the other solutions in DG - none worked
Have done a complete uninstall/ re-install - not working still
Applied as many service paks to system as I could - not working...
Thanks in advance for any/all help.
BT
3 REPLIES 3
in reply to: Btimmerman
Btimmerman said the following On 3/13/2007 1:15 PM:
This is peer-to-peer user forum. It's not designed to communicate issues
directly to Autodesk technical support. Although there are some Autodesk
people in the C3D and DWF forums, I wouldn't hold out for it here.
How to access Autodesk support:
1. From the Contact Us link from the Autodesk website:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2172022
2. From the Support link from the Autodesk website:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2786107&linkID=2475874
3. From the Support link from the Autodesk website, pay for
direct autodesk support if you don't qualify for the
restriction noted above:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=2915212&linkID=2475874
4. From the Support link from the Autodesk website pay per
incident if you don't want to sign up for a support
contract:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=7031104&linkID=2475874
5. From the Support link from the Autodesk website hit the
free email posted on their website and hope it gets through:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1074348
6. Contact Numbers:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=7031104&linkID=2475323
7. Contact your reseller.
R.K. McSwain
http://rkmcswain.blogspot.com
Btimmerman
OK...call of the dogs...the issue has been resolved.
It was a evidently another file associated with the arx file. Once the file was reloaded my civil series 2004 came back "on-line". The only problem is that I'm not sure which file corrected the issue. The other app that was removed also removed the common file and the big thing is that I said NO to remove common files during the uninstall of other app. so, their application has some "bugs" in it during uninstall...similar to the "bugs"/Features in AutoCad/civil/etc...
so, for now things are back to normal...what normal is I'm not sure.
B Timmerman
HHE
Hiawatha, IA
snip>what normal is I'm not sure.
The ability to get the Projects...
Designed;
Approved;
Constructed;
As-Built;
Enjoyed by the public, long after we've retired?
;0)
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
C3D/LDT/CD-2K7 SP2A
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5517242@discussion.autodesk.com...
B Timmerman
HHE
Hiawatha, IA
