• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    Active Contributor
    add vertices to viewport
    3333 Views, 5 Replies
    09-27-2005 01:12 PM
    Is there any way to add vertices to your viewport?
    Please use plain text.
    Re: add vertices to viewport
    09-27-2005 01:15 PM in reply to: cgib
    vpclip might do what you are looking for. You can increase or decrease the area of the viewport with this command. However, when you create the viewport (MVIEW or MV), you have the option of creating a polygonal viewport. Hope this helps.
    Distinguished Contributor
    09-27-2005 01:40 PM in reply to: cgib
    If you create polygonal viewports or convert objects to a viewport, you can use the standard pedit on them and then V for vertices and then I for insert. It works but you have to have created the viewport by one of the previous two methods. It won't work on a regular rectangular viewport. I convert all mine from a rectangle and that way if I want to add vertices later it will work.
    *Don Reichle
    09-27-2005 01:58 PM in reply to: cgib
    And a very well-planned scheme for future needs - whether they appear or
    not. :-)
    Don Reichle
    "King Of Work-Arounds"
    "The only thing worse
    than training your staff,
    and having them leave is -
    not training your staff,
    and having them stay."
    Courtesy Graphics Solution Providers
    LDT-2K4
    AMD64 3200+
    XPPro 32bit SP2
    1GB RAM
    Nvidia GeForce FX 5200 128MB
    Western Digital Raptor 10K-rpm HD
    wrote in message news:4968575@discussion.autodesk.com...
    later it will work.
    New Member
    Justin_A
    08-13-2012 07:31 AM in reply to: cgib
    Awesome! VPCLIP worked perfectly for me you just have to draw the desired outline of the VP.
    New Member
    Re: HIII Dude...
    09-18-2012 12:31 AM in reply to: cgib
    Dear Friend....
     we can show horiz. plane drawing in model space to vertical plane in paper space..
    MV    -   Enter
    Draw a window and double click in that window and thenchange UCS-in Z-Axis to 90 then
    go to VIEW-3Dview-plan view-current UCS  that's it.
    i hope it will helps UUUUU...
    Regards
    Gkkreddy :smileyhappy:
