AutoCAD Land Desktop (Read Only)
Where is the workspace info stored?
9 REPLIES 9
Message 1 of 10
24043 Views, 9 Replies
Setting up new pc and I want to copy the setting over for these to the new
one?
Todd W
LDD 2009, Civil 3D
XP Pro SP3
4 G Ram
9 REPLIES 9
Message 2 of 10
It's in the main menu (CUI). In the cui editor there is a Transfer tab you
can pen both main and this 'other' cui and drag the workspace from one to
the other.
"Todd W" wrote in message
news:6108591@discussion.autodesk.com...
one?
Todd W
LDD 2009, Civil 3D
XP Pro SP3
4 G Ram
Message 3 of 10
In Options, under the profiles tab, click "export". Save an .arg file somewhere onto your network. On the new pc, follow the same options steps, except click "import" and import the arg file, then set it current. You can lock the settings by saving the workspace at this point. I hope that helped.
Message 4 of 10
Workspace is stored in the menu (cui) file, not the
CAD profile (arg)
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
In
helped.
Message 5 of 10
I was just trying to rocommend a quick resolution. You can import an arg file and save it as a cui in the new PC. Either way works similarly, except if you're trying to standardize things company-wide - like printer settings and support files paths in Options, the arg file saves those settings as well. I'm not sure if the cui file does that.
Message 6 of 10
They're actually 2 completely separate environment
files.  The arg stores everything in the OPTIONS tabs (variable settings,
paths, etc), but does not contain any of the GUI/Menu/Toolbar layout or screen
organization (except for screen colors).  The cui contain all the
commands, toolbars, shortkut keys, pop menus and the way they're
laid out on the screen (the workspace).
You can't save an arg as a cui.  The arg
specifies where your main and enterprise cui files are loaded from, but that's
the only tie.
I
Message 7 of 10
I guess my AutoCAD is different. I can import and arg file and set it current in my options. My toolbars and pull down menus change to how the environment was at the time the arg file was exported, as well as the OPTIONS parameters. I then save my workspace and everything seems to stay that way. Try it. It really works
Message 8 of 10
Your CAD profile probably references a main
customization file that has a default or current workspace that is set to what
you see when you set the profile current.  (Or maybe we just
have different AutoCADs)
I
really works
Message 9 of 10
What is the simplest, most effective way to mange a "main" cui globally, while allowing users to sustain their own workspace environment?
Message 10 of 10
Create you own Enterprise cui file
