• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    New Member
    Unhandled Exception: App doesnt support JIT Debugging
    799 Views, 0 Replies
    04-25-2012 11:51 AM
    I am running AutoCad Civil 3-D Land Desktop Companion 2009 and when I open any drawings up I get this error message.  Not sure how to fix this.
    Unhandled exception has occured in a component in your application.  If you click continue, the application will ignore this error & attempt to continue.
    Invalid URI: The format of the URI could not be determined
    Application does not support just-in-time (JIT)
    debugging. See the end of this message for details.
    ************** Exception Text **************
    System.UriFormatException: Invalid URI: The format of the URI could not be determined.
       at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
       at System.Uri..ctor(String uriString)
       at Autodesk.InfoCenter.CommunicationCenter.PopulateContents(ResultItemCollection& contentCollection, ICommCntrChannel channel)
       at Autodesk.InfoCenter.CommunicationCenter.GetContents(ResultItemCollection& channelContents)
       at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter()
       at Autodesk.InfoCenter.PaletteMgr.get_CommCntrSrc()
       at Autodesk.InfoCenter.PaletteMgr.LoadCommCenterSources()
       at Autodesk.InfoCenter.PaletteMgr.InitCommCenter()
       at Autodesk.InfoCenter.PaletteMgr.InitSources()
       at Autodesk.InfoCenter.PaletteMgr.FirstInvoke()
       at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e)
       at System.Windows.Forms.Application.RaiseIdle(EventArgs e)
       at Autodesk.AutoCAD.ApplicationServices.Application.OnIdleWinForms()
       at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.3623 (GDR.050727-3600)
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    acdbmgd
        Assembly Version: 17.2.0.0
        Win32 Version: 17.2.56.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcdbMgd.DLL
    System
        Win32 Version: 2.0.50727.3620 (GDR.050727-3600)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.F...
    System.Drawing
        Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    PresentationFramework
        Assembly Version: 3.0.0.0
        Win32 Version: 3.0.6920.1500 built by: QFE
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFra...
    WindowsBase
        Win32 Version: 3.0.6920.1453 built by: NetFX
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationCore
        CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
    msvcm80
        Assembly Version: 8.0.50727.3053
        Win32 Version: 8.00.50727.3053
        CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.3053_none_d08d7bba442a9b...
    acmgd
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/acmgd.DLL
    AdWindowsWrapper
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AdWindowsWrapper...
    AdWindows
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.56.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AdWindows.DLL
    System.Xml
        Win32 Version: 2.0.50727.3074 (QFE.050727-3000)
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    ResourceManagement
        Assembly Version: 12.0.48.0
        Win32 Version: 12.0.048.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/ResourceManageme...
    AdWindows.resources
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/en-US/AdWindows....
    PresentationFramework.Aero
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/Presentati...
    AcMgdReverse
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcMgdReverse.DLL
    Redland.NET
        Assembly Version: 1.0.2.1
        Win32 Version: 1.0.2.1
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/Redland.NET.DLL
    AecDtlDb
        Assembly Version: 5.7.68.0
        Win32 Version: 5, 7, 68, 0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AecDtlDb.DLL
    AecDtlDbUI
        Win32 Version: 5.7.68.0
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AecDtlDbUI.DLL
    AecDtlDbLib
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AecDtlDbLib.DLL
    AcInfoCenterConn
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcInfoCenterConn...
    AdInfoCenter
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AdInfoCenter.DLL
    AcWindows
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/AcWindows.DLL
    AdInfoCenter.resources
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/en-US/AdInfoCent...
    Accessibility
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Configuration
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configura...
    System.Web.Services
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Servic...
    Autodesk.Interop.WSCommCntr1
        CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202009/Autodesk.Interop...
    ************** JIT Debugging **************
    Application does not support Windows Forms just-in-time (JIT)
    debugging. Contact the application author for more
    information.
    Please use plain text.
