jacoppinger,
I ran into this while using LDD2004. The problem is not in LDD, the problem
lies within the "Intellizoom" function, which is the name of the zoom that
you use with your wheel on your wheel mouse. I tried the same thing, in a
working drawing, when I had the problem. I drew a few circles, lines, did
some regular zooms and realtime pans, did a wheel zoom, and then a few more
commands. I found that the undo stopped after the last "Intellizoom". In
fact, there's an OLD thread on here from me (about 2 or 3 years old)
concerning such. A fresh install should fix the problem.
Dennis Hyman
Cad Tech. - Survey Dept.
Stock & Associates Consulting Engineers
LDD 2004, Civil, Survey, Map
2.4 Ghz P4, 512 MB RAM
GeForce 4 MX 440 Graphics Card
wrote in message news:5489412@discussion.autodesk.com...
Yup, I get your drift! 🙂
Let me see if I can explain the steps for you both:
1. Launch Ldd from a desktop icon
2. open a file (any)
3. copy, move erase, draw a few lines on screen, zoom to a few different
locations.
4. Check your UNDO list - it looks fine. ZP also works.
5. Run an LDD function (Terrain Model Explorer or Drawing Setup)
6. Now look at UNDO and ZP. Neither works (on our systems anyway)
When LDD loads into the file the first time it seems to clear the cache for
both functions.
