AutoCAD Land Desktop (Read Only)
Turning off layers in X-ref
6 REPLIES 6
vberinger
2096 Views, 6 Replies
For some reason, LDD won't let me turn off a layer that is in an X-ref. It will let me freeze it, but I just want to turn it off. Does anyone know how to fix this?
6 REPLIES 6
in reply to: vberinger
How are you trying to turn it off?
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008, LDT 2008, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
wrote in message news:5669482@discussion.autodesk.com...
to fix this?
vberinger
By layer off (the little light bulb).
When you hit the button, the command line has options. Type S for settings &
then B for Block. You most likely have this function set to NONE. Try Block
or Entity. Mess around with both settings to see what they do & note that
the layer freeze command has the same options.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
wrote in message news:5669547@discussion.autodesk.com...
vberinger
It works, Thanks! Both of them seem to work the same way. I am sure there are differences, but I just kept it set to Entity.
They do work different. Depends on what you select. Type LAYFRZ in Help. The
Quick Reference has it summed up very nice.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
wrote in message news:5669590@discussion.autodesk.com...
Let me correct that last one. It depends on what you want turned off. The
layer the block/ref is on or the layer that the block's entities are on.
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
"John Mayo" wrote in message
news:5669638@discussion.autodesk.com...
John Mayo
Project Engineer
Conklin Associates
Ramsey, NJ
P-IV at 3.5 GHz
2 GB Ram
