• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Land Desktop
    Active Member
    Text Won't Mask - Hold's Z-Position
    131 Views, 7 Replies
    04-24-2007 10:49 AM
    Unable to mask text in ACAD Land Desktop 2007. The particular text which I'm trying to mask will not flatten to zero and I believe that this is what is causing the problem. Manually editing the properties and 'Flatten Z-values' to zero don't work. If I edit the text alignment z to 0 I still get a position z of something like -0.017302934. When I run text mask on said text, I get a return of "Invalid option keyword". What is going on with my text that I cannot completely set it's z-coordinate to zero? I have tried moving it 0,0,0 and yet nothing. Running out of ideas and I have about 300 text objects that need masks. Please help.
    Thanks.
    Please use plain text.
    *Allen Jessup
    Re: Text Won't Mask - Hold's Z-Position
    04-24-2007 11:31 AM in reply to: JMont
    Convert them to MText and use the background mask. I know it doesn't address
    the elevation problem but it'll get you plotting in the mean time.
    Allen
    wrote in message news:5562809@discussion.autodesk.com...
    Thanks.
    *Don Reichle
    04-25-2007 05:05 PM in reply to: JMont
    And since you mentioned LDT 2K7, then everybody has been expecting me to ask
    if you've got the necessary Service Packs for this release yet JMont?
    If not then the WebPage for them is in the tinyurl:
    http://tinyurl.com/25un8x
    HTH
    Don Reichle
    "The only thing worse than training your staff, and having them leave is -
    not training your staff, and having them stay." :-o
    A reminder taken from Graphics Solution Providers' Calendar page
    !! Please discuss whatever we tell you with your SysMgr !!
    !! They appreciate staying in the loop :-) !!
    LDT-2K4
    AMD Athlon64 2.2GHz 2GB RAM
    XPPro 32bit SP2
    WD Raptor 10K-rpm 37GB HD
    Nvidia GeForce FX 5200 128MB
    "The only Constant is Change".
    "Allen Jessup" wrote in message
    news:5562879@discussion.autodesk.com...
    Allen
    Thanks.
    Active Member
    04-27-2007 05:32 AM in reply to: JMont
    Thank you for the reply's. I have not been able to solve this problem yet. I have been able to workaround it by wiping out rectangles around each text object. Below is my current system's configuration. I have had Service Pack 2A since it came out several months ago.
    System:
    Gateway, P4, 2Ghz, 1.5Gb RAM, Windows XP Professional SP2
    Autodesk:
    Autodesk Land Desktop 2007 (Service Pack 2a)
    Autodesk Civil 3d Civil Design Companion 2007
    Autodesk Survey 2007
    Autodesk Land Desktop 3 2000 (Service Pack 1)
    Autodesk Civil Design 3 2000
    Autodesk Survey 3 2000
    *Don Reichle
    04-27-2007 03:41 PM in reply to: JMont
    Not that it "should" be of consequence with the issue you've brought up
    JMont, but after you installed the 2K7 "product line", did you perform a
    Repair on the previous "product line" you mentioned?
    That comes from the ReadMe on the CD/DVD (since around the LDT 2000i
    release), so you can check that out for yourself - when you have the time.
    And I always had a 2002 dwg file format, when I used LDT 3?
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    wrote in message news:5566705@discussion.autodesk.com...
    System:
    Autodesk:
    Active Member
    04-30-2007 08:17 AM in reply to: JMont
    Hi Don,
    Yes, I repaired my 2002 LDT after installing 2007.
    And I should have wrote 2002 instead of 2000.
    *Don Reichle
    04-30-2007 02:14 PM in reply to: JMont
    Well then there's only one more option for you to try, as far as I know, and
    it's fairly extreme I should warn you:
    http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=8018911&linkID=9240777
    I've seen that help others here with the problems they've reported with LDT
    2K7.
    HTH and discuss this recommendation with your SysMgr prior to implementing
    it please.
    Don Reichle
    LDT-2K4
    XPPro 32bit SP2
    wrote in message news:5569161@discussion.autodesk.com...
    Hi Don,
    Active Member
    08-22-2007 08:14 AM in reply to: JMont
    I think I've found out what is causing this issue. It seems to be that the contour labels I am trying to mask are not aligned with the UCS. In this case, how do I go about aligning text to the UCS? Has anyone found a solution to this?
