AutoCAD Land Desktop (Read Only)
Terrmodel to AutoCad Lines
9 REPLIES 9
Message 1 of 10
Buick87GN
603 Views, 9 Replies
Hello! Anybody converting from Terremodel to Autocad? I'm trying to get line types like the Terramodel ones. See enclosed png. This TM line type called Sewer and MH. It automatically sets the manhole at the end of the polyline and then inserts the text S and equally spaces it between manholes. Any ideas are of course greatly appreciated. Thanks in advance
9 REPLIES 9
Message 2 of 10
in reply to: Buick87GN
If you open the Acad.lin file you will see linetypes that contain text. Copy
one of those to the end of the section and replace the text with an S.
To find which acad.lin you are using use (findfile "acad.lin").
Something like this:
*S_LINE,Gas line ----S----S----S----S----S----S--
A,.5,-.2,["S",STANDARD,S=.1,R=0.0,X=-0.1,Y=-.05],-.25
Allen
wrote in message news:5567572@discussion.autodesk.com...
Message 3 of 10
And there are LIN files up on the Customer Files DG also, already setup for
either Metric Linetypes (Laurie Comerford placed his set there back a couple
years ago), or Imperial Linetypes (I placed my set there at roughly the same
time).
You can easily find both of them by using "civil linetypes" - w/o quotes -
in a Search of that DG Buick87GN.
I determined quite a while ago, that the Lines?Curves>Special Lines made way
too many "pieces" for my tastes. 😮
And for the Manholes (and other types of these Blocks in AutoCAD), you might
want to think about using Dynamic Blocks - see the attached 2K7 dwg file if
you've got 2K7 at your firm?
I didn't have 2K6 when I created that DynBlock, so that's why I mentioned
the release data for you.
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
"Allen Jessup" wrote in message
news:5567606@discussion.autodesk.com...
Allen
Message 4 of 10
But Allen, he won't get those little circles for manholes.
Bill
Message 5 of 10
Maybe I presumed too much?
"wfb" wrote in message
news:5567757@discussion.autodesk.com...
Bill
Message 6 of 10
Buick87GN
Hi Guys: Maybe I'm missing something here. Ww are converting from Terramodel to LDT 2007, NO CIVIL 3D. Terramodel's sewer linetype and other similar lines creates a manhole at each point in your polyline, adds the "S" text and centers it and the line segments between the manoles or points on the line. (See my png in opening post) In Acad, I can' t seem to do this. Allen's tip is ok for just lines with text, but I was trying to replicate what we can do in TM with adding manholes.
Message 7 of 10
Buick87GN said the following On 4/30/2007 7:37 AM:
> ... but I was trying to replicate what we can do in TM with adding manholes.
Can't be done in stock AutoCAD, without a custom ARX app.
R.K. McSwain
http://rkmcswain.blogspot.com
Message 8 of 10
Buick87GN
So I guess I'm out of luck unless there is someone out there that knows how to make a custom ARX app. to do this line type.
Message 9 of 10
And I'll just reiterate just a little in these regards...
Since the only constant is change, then there's all those separate entities
to be erased (in the AutoCAD dwg file) when the utility being designed goes
through yet another revision in horizontal location
Which is my main reasoning for developing and using custom linetypes.
Please.see the attached Zip file Buick87GN.
Off-topic reply>
And BTW, Ebay has a fairly good selection of those cars you have as your
"handle":
http://tinyurl.com/yoy7fs
Don Reichle
LDT-2K4
XPPro 32bit SP2
"R.K. McSwain" wrote in message
news:5568909@discussion.autodesk.com...
> manholes.
R.K. McSwain
Message 10 of 10
Buick87GN
Hi Don: The wife and I both love our original stock 87 Grand National with T-tops. It's such a blast to drive and blow away Mustangs. Thanks for Ebay ref.
