AutoCAD Land Desktop (Read Only)
Symbol Manager Pathing
2 REPLIES 2
535 Views, 2 Replies
I have searched this discussion group, and read what Karl said in the Customer Files group. But I'm still fuzzy about why my Symbol Manager is not finding a specific block.
Here's my scenario:
I have our Symbol Manager files on the server. And the SYMDATA path in the sdsk file is pathing to the server location. The server location is in my support file paths. But when I try to insert this one specific symbol I keep getting this error:
"pcor.dwg": Can't find file in search path:"
and then is lists every support path, including " N:\CADD STANDARDS\LDD_SUPPORT\data\SYMBOL MANAGER\Cogo\" where my symbol is. I've tried this pathing just to data, then to data\SYMBOL MANAGER as well.
The search path in my Point Settings > Insert is also directed to the server symbol manager\ or symbol manager\cogo\ (I've tried both).
Unfortunately, no one else in the office knows any more about Symbol Manager than I do, so I turn to you for advice.
Thank you.
2 REPLIES 2
Gina when you select the Manage button (upper right portion of the Symbol
Manager dialog box), does it show the nomenclature you've mentioned...
...or does it show something else in the Expanded File:, down in the lower
left portion of the Symbol Data Management dialog box?
Don Reichle
"The only thing worse than training your staff, and having them leave is -
not training your staff, and having them stay." 😮
A reminder taken from Graphics Solution Providers' Calendar page
!! Please discuss whatever we tell you with your SysMgr !!
!! They appreciate staying in the loop 🙂 !!
LDT-2K4
AMD Athlon64 2.2GHz 2GB RAM
XPPro 32bit SP2
WD Raptor 10K-rpm 37GB HD
Nvidia GeForce FX 5200 128MB
"The only Constant is Change".
wrote in message news:5588600@discussion.autodesk.com...
Here's my scenario:
getting this error:
Thank you.
cobradood
from symbol manager click the edit button, there you can hit the block button and directly point to your block.
might want to verify that you can indeed traditionally insert the block in the 1st place.
