I have never heard of this one Glenda. A few guesses.
Have you tried to open the dwg w/ a recovery and then running audit. Any
errors in either?
Is this limited to one file or project? If it's a single file, is it from an
outside source with a file lock on it?
If multiple files & projects are affected have you run a repair?
John Mayo, PE
Project Engineer
Conklin Associates
Ramsey, NJ
Civil 3D 2008 SP2, LDT 2008 SP2, Raster Design 2008
P-IV at 3.5 GHz
2 GB Ram
Nvidea Quadro FX w/ 128 MB Ram
"Glenda" wrote in message
news:5937203@discussion.autodesk.com...
My setting are not being saved. I have never had this problem before. Has
anyone experienced this? I am using Windows XP and LDD2, Civil
Design and Survey. When I go into "Modify dimensions (ddim) for example the
settings aren't saved.
Glenda
